When the engine just have been started, the headlight is weak, the light in display is gone, and the engine dont run properly. and when the engine is warm it runs great, but the light is going on and of, handwarmers dont work at all.
I know there has been some problems with earlier SRX's with the cableruting under the engine, but has anyone had this problems with the viper?
Yes, try searching for cable rub. If you don't find a cable issue, test your electrical components including the stator. Procedures should be in the Tech Pages.
http://www.totallyamaha.net/forums/showthread.php?t=57116&highlight=viper+high+beam
mine would reset the tach when i turned high beams on. Stator.
