1998 srx has blown out head and tail light,which voltage regulator controls the power to the lights? the one with the wire i=or the one that plugs in?
I dont understand this?^^ clarify..sxr1000 said:the wire i=or the one that plugs in?
there are two voltage regulators, one with a wire and one without,which one controls voltage for the lights?
where are you getting two from? i see only 1sxr1000 said:there are two voltage regulators, one with a wire and one without,which one controls voltage for the lights?
1 v reg
1 DC reg
1 condenser
but to answer your q the v reg controls the HL, blue wire
I looked at the yamaha parts fich and part 20 and part 32 are both called votage regulator assembly, so the one with the pigtail wire is the one I am after correct?
mopar1rules
lyle, i might have a regulator for you, if you need one. i'll have to check the parts bin.
