will a 80 srx clutch work in a 79? whats the difference? how about comet clutches, will one fron a 80 work on a 79? awsome site, helps me alot. thanks GUYS!
dynofun
- Nov 14, 2005
Yes it will. You may need to change the weights to match the secondary or change the secondary to match the 80 tho.
YAMMIEGOD3:16
THE YAMAHA PRIMARY CLUTCH ITSELF IS THE SAME ON THE 79 AND 80. DEFFERENCE IS IN THE PRIMARY SPRING AND WEIGHTS. NOW A COMET 102 c FOR A 1979 SRX WILL NOT WORK ON A 80 BECAUSE OF THE OIL INJECTION GEAR. 80 TOOK A DEFFERENT 102 c AND THEY HAD DEFFERENT PART NUMBER. 3:16 (yammie tony)
