warning light has been going. The code description reads: Open or Short circuit. Checked the connections on the back of the switch, look good....Thoughts?
Hook on ohm meter up to the two contacts. Turn the dail slowly and watch for changes in the ohm readings. It should gradually increase or decrease. If is goes to open or close to zero ohms then the switch is done. Also check the grip warmers and thumb warmers.
will check that...I'm pretty sure the switch done...The handwarmers run very hot now no matter where the dial is set. Anyone know the part number on the replacement?
