TeamHard24
Im converting into a 136" on my Viper and was thinking going 1.25.
What are good brands? Been to tracksusa but want a good track for trail riding that I can stud and hold up boondocking. Maybe it doesnt matter.
Buying 8T drivers and does that make a different as well?
And can I go 15" or 16" wide.
ottawaair
I rnning a 136 X 1.25 ripsaw, pretty happy with it. studded with 162 1.5" studs.
If the drivers you're getting are the anti-ratchet style then the track needs to be open every window for the driver teeth. 15" wide.
yamahahaha
ripsaw
TeamHard24
ok. so I found a 16" wide from a renagade. that wont work then
TeamHard24
ottawaair said:I rnning a 136 X 1.25 ripsaw, pretty happy with it. studded with 162 1.5" studs.
you must hook up really good if you have 1.5 studs
Check out the 136" Camoplast Ice Ripper XT. It's a Ripsaw 1.25" with 240 pre-moulded carbide tipped lug studs. The studs add less than 1 lb in total weight, and the track is single-ply so it's a weight saver. My buddy has one on his Attak and he loves it.
