94 vmax 500 st suspension
cheed19
Dover-Foxcroft,ME
i have a 94 vmax and i was wondering what my options were to make the rear end sit higher. i dont want to put any new shocks or springs in just want to know the necessary adjustments needed. anything will help!
you cant really get it to sit higher than stock without bying parts,if you mean when your on it it sinks alot, you can adjust the shocks springs stiffer thats about it.
I have tried moving the rear suspension to the different setting but the one set of the boggie wheels in the back got in the way.
If your trying to add clearence for deep snow, you could probably use drop brackets to lower your suspension mounting points. You would have to do your homework to come up with the new mounting locations.
I made some drop brackets today took about two hours to fab up and mount, they make the old girl sit up a little taller and it looks bad *** ;)!
