GetHighRacewear
I am putting my rear suspension back together in my 2003 Viper and need to install the rear axle. Which way to the chain adjusters go in? The long stud that sticks out to the rear, pointing inward(towards each other) or outward?
Thanks, Gary
Thanks, Gary
gild
chain adj
no idea what you are describing, pics? more info needed
GetHighRacewear said:. Which way to the chain adjusters go in?
Thanks, Gary
Stumped. The only chain adjustment that I know of is in the chain case.
rx1jim
You must be talking about the pieces that the axle go through to adjust the track tension. I know what you are talking about, the threaded stud on the adjuster comes off the short tube on and angle. I believe the part is installed with the stud pointing outward. You'll know when you put it together since I believe it will fit only one way.
staggs65
track adjuster?
hmmmm.....
super1c
Super Moderator
Im sure he's talking about the track adjusters. you want them pointing away from eachother. Pointing out. I know only because it put them pointing in and it made it a bi@@$h to adjust the track!!!
With a screen name like "GetHighracewear", Im not sure he knows what he's describing!! lolgild said:no idea what you are describing, pics? more info needed
Just kidding, give us a better desription of what your asking.
Are you asking ,which way do you need to turn the nuts to tighten the track?
