was wonder who useing it and is worth it or not
rx1jim
The Bender kit is supposed to inject the oil directly into the carb and as teh gas passes by the injection point it mixes with the oil. It is supposed to be better for the engine since there is much less delay between the throttle position and the delivery of the right amount of oil. Personally, i like the idea of injectingthe oil into the fuel line to get complete mixing. To install the Bender kit, you need to drill the carbs and install the nozzles. I don't trust this kit, the stock system has worked for many years on thousands of sleds and motorcycles.
bufalobob
yamaha is the only sled manufacturer that injects oil into the fuel pump. everyone else injects into the cylinder or crankcase. that works on a stock motor but on a modified motor i would change to the bender kit.
bob
bob
09nytro
I have a 02 viper with it on never had a problem I love it
I have a srx 700 was looking at that bender set up as well, any one recommend it ?
mopar1rules
eric.s.t said:I have a srx 700 was looking at that bender set up as well, any one recommend it ?
i personally would leave the bender kit off, but that's just me i guess. nothing wrong w/the yamaha setup.
09nytro
i like it u don't have the delay of oil when u hit throttle to ricken up u have to burn all the gas out of carb this way it just injects right into carbs when you need it
