I got this last year sled thru a bud of mine. it only had 500k on the odometer and it was cheap. had blown pistons which I have replaced and it runs fine now. Have traced THAT problem to the former owner using the wrong plugs in it. I had though maybe it had an air leak in the crank but I have ruled that out now. My recent issue has to do with the fuel and oil lines.
I was replacing the old, stiff fuel and oil lines with new ones and I broke a fitting(and on a sunday when all the shops are closed) I managed to find one from a boneyard nearby tg. It is a double t-fitting that is on the main fuel line from the tank before it goes into the fuel pump. There are 2 lines that connect to this double tee-fitting and they come from the oil pump(I replaced these lines as well). Well in my haste I neglected to pay attention to which line went to which nipple on the tee-fitting. One of the oil lines comes off the front of the oil pump and the other oil line comes off the side of the oil pump. Both lines run to this double tee-fitting on the main fuel line. I am not sure if it matters which oil line connects to which nipple on this tee-fitting. looking at it it would not seem to matter but I want to be sure.
Anyone have one of these beasts out there that might want to lift there hood and let me know how its supposed to look??????
This seems like an odd way to inject oil into the system as my other sleds(96 venture 485cc :94 bravo) both inject the oil directly into the carbs as do most other snowmobiles. Any ideas there or has someone just got creative in their repairs on this machine before I got to it lol?????
Also I want to install an inline primer on the fuel line. similiar to the type of primer found on small outboards. Where along the main fuel line would be best to insert one????????? I was thinking of placing it in the section of fuel line after the tee-fitting I mention above, and before the fuel line enters the fuel pump as it is the only area that has room to accomodate it. Any ideas?
I have tried to find a service manual for the 410cc engine but havent had any luck. I am not looking for a freebee(though that would be nice) and am willing to pay for one. Anybody got a copy for sale??????
I know these are not yer performance sled of choice but they get me to where I want to go and they are tough and I am sure there must be plenty of these ut sleds out there.
I would love to hear from any of you that own/run one!!!
Maybe I should just disconnect the oiler system and run mixed feul!!!! The easy fix I know but I like the oil injection I have in the other sleds I ride.
Thanks to all who may have any ideas!
Prayin for snow out here in cariboo BC
corcan1
should not matter which line connects where.
my 89 exciter has the same type of oil injection system.
not sure about adding a primer. never done it.
Maim
Super Moderator
it mixes the oil in the fuel pump like all the sxr/srx/vipers. the primer ball should go in the fuel line between the pump and the tank. should not need one though if it is run every 3-4weeks. longer than that, need gas in the cylinders or a real good pulling arm.
would the manual for a 1992-2001 et410 do you some good? i have one of those thanks to another site member (just need to find the disc).
thanks for the info! I didnt think it would matter either.
Maim said:it mixes the oil in the fuel pump like all the sxr/srx/vipers. the primer ball should go in the fuel line between the pump and the tank. should not need one though if it is run every 3-4weeks. longer than that, need gas in the cylinders or a real good pulling arm.
Thanks for the info Maim! I am going to put her all back together this weekend and if it snows(please gods of snow hear me) enough to get her out on the lake and test run her.
I know it shouldnt need a primer, the choke works just fine. I wanted it for that first start up of the season and when the real cold comes. Just thought it might make my life easier is all. My bravo has a plunger type primer and it starts so much easier with it. That and the wife is tired of doing all the pulling lol.
The manual you have sounds like it should work. Its the same motor and I cant see them changing it much except to change the way the oil is injected
Let me know what you want for it
Thanks again
Maim
Super Moderator
let me see if i can find it and then i will rip you a copy ot post it up on the net in my pb acct.
