YamahaGuy-1
I posted this elsewhere but realized I should probably put it here.
Question on the 96 500 vmax xt I just picked up. The secondary clutch will twist when you grab each side and turn them in opposite directions, after approx. 1/8 turn it then hits like a stopping point, but if you really push you can get them to begin to separate like they should. when you let go they both spin right back into closed position like they should no problem. I have never seen one do this, all others that I can recall started to separate immediately when I started twisting. Is this normal for a 500 or do I have problems?
