What are the stock jets for a 2000 SXR 700?
I don't see the SXR on the spec sheets
What is it the same as?
stock jetting: mj#1-145, mj#2#3- 143.8. pj#45, jn 3, fuel screw 1 1/2 turns. dont know how its listed in the tech section, these numbers are from the book listed as a SX700D.
Hey thanks
Does in matter about sea level or anything?
I am in Ottawa
I am in Ottawa
the info i gave you was for 300-1700'(100-500m) @20*F/-7C.. thats is what the sleds were delivered with. lower elecation means leaner, so again from the book, same temps, at sealevel to 300"-146.3,145,45,3,and 1 1/2. same order as above. as you may know, yamaha is normally conservative on there jetting, so you are probably fine, but dont hold me to that.
