Tunnel extensions
96YamVmaxXT
Maine
Does anyone make a 136" or 144" tunnel extension for the pogo style vmax? I'd like to put a 136 under mine with a 144 tunnel extension but cant seem to find someone who makes them... Anyone know?
Why are you putting on a 144 extension and only using a 136 track? The tunnel extension is really no big deal to add. Check out Hartman or tracks USA Al
BARON 8BU said:
You should be able to get the 136 factory extension right from a dealer ship.
From the dealer probably worth more then the sled lol.
But on the lighter side, I would go with the 144, my buddy has a Switchback, with 2 inch lugs and only a 600 and it goes through anything, amazed the hell outta me. And since the Switchback is kinda like out Yammy's in the fact it is low in the front and has a tendancy to nail a drift, it is a good comparison.
But you can also have one fabbed up, not like it is a huge deal, just get it bent and rolled, and put some reinforcment tubes inside it so you can still lift it from the arse end.
If you have the tools you could even do it yourself.
I just finshed mine. I have pictures in the photo section. I looked for a extension and no one has them. I called Hartman and he has not had any for some time. I ended up building my own. I used aluminum angle and built the frame and skinned the top with aluminum sheeting. I overlapped onto the original tunnel by about 10 inches then made a new bumper that ran out from original holes and added another set on the extension. It is pretty sturdy and helped strengthen my original tunnel.
Would the kits from mountain perofrmance also work on my son's 97XTC 600 needs a track soon thought it would be a good time to extend it.
