no1chevyboy
what kind of trail riding miles are you guys getting on a belt before its worn out
as long as they are within specs..use them.Mine are still good after a couple seasons and still going strong.new is 34.5mm width,wear is 32.5mm width.I am at 33.5 to 34 mm yet.As long as your clutches are aligned properly.will go for a good time.
I get between 2-3000 miles on average.
I replace the belts every year on each sled, This is usually after aroung 2k miles. I put the old belt as a spare, move the spare to the trailer rack. I have never had to replace a belt midseason. This also goes for the spark plugs. Al
jasonlmrx
i change mine once every two years.. and during summer i put the blets in a plastic bag and put them in the bottom of my freezer to make sure they dont crack.
Jason.
Jason.
grapeape
Most miles on a belt for me is over 5000, with over 120 miles of towing another sled. Secondary belt adjuster, and cleaning the clutches and belt after every trip helps a lot. 2-3000 is a good average for me unless I "burn" one when stuck.
no1chevyboy
ok i have about 800 miles on a new belt and i just had to put the washers back in it measures 1.370 now new it measures 1.400
