marty f
Trying To Tune Up My Friends Sxr700 And Went Thru Cleaned The Carbs Etc.now My Friend Took It Out For A Ride After And He Keeps Fouling The Middle Plug Or Could It Be Something Else?
marty f
Tors Is Disconnected!
Tors Is Disconnected Also,so Why The Intermittent Power Loss
Did you check to make sure the choke plungers aren't hanging up? Is the choke cable set to tight? are the fuel adjuster screws adjusted correctly? If the plugs are changed does it run fine then runs like crap again? Just a couple of thoughts?
marty f
it runS fine then runs like crap again
it runS
it runS
maybe your plug caps are bad.. I've gone thru 3 sets of em in my sx!
JTSX700
like bandit said check the choke plungers.
