Yamaha Exciter OIL INJECT
YamahaSXR700
River Valley
Alright guys, i got a yamaha exciter and theres two oil inject line that goes in the gas line, is it normal that it does there, or they go to the pump to the carb? just a lil problem, because i do have plugs on my carbs, to put little lines like them, i dunno if its there they are suppose to go let me know please and thank you
on the exciter it goes to the fuel line before the fuel pump.
on my 89 i too have those connections on my carbs with black cap's covering them.
i don't know if it would work properly if connected there and omited the special connector in the fuel line.
i think its better in nthe gas line because it mix them together as if u wouldur lines in the carb plug it would go strait oil
actally the two small fittings with the rubber caps plugging them are to be used for attaching a carburetor syncronizer.
