sledman67
Just wondering if anyone else here with a 85-90 Phazer has put a tunnel extension on there sled.Also where would I find a reasonably priced one?I'm located in central Ontario,Canada.I was thinking it would help with tunnel bracing and someplace to carry a jerry can of gas.
BigMan76
I put a stock one from Yamaha on a short-track Phazer and also bought a Phazer that was extended with a Hartman tunnel extension.
JordanHall488
Were did you find a yamaha one? I cant seem to find anything, mabe you could find one with the part number
Hey guys if you need parts fabbed up I am a sheetmetal fabricator by trade and can bend you one up out of aircraft grade aluminum if you are interested. Pm me for details. Bandit
srv540
gets some drawings done and lets get a group buy going i would be in!
PZ 1
- Mar 12, 2005
Find a junk phazer (or other Yamaha with the same dimensions) and cut a piece off the rear of the tunnel and shorten the sides.
sledman67
I was actually thinking of doing that...LOL..That or making one out of sheet metal.PZ 1 said:Find a junk phazer (or other Yamaha with the same dimensions) and cut a piece off the rear of the tunnel and shorten the sides.
Hartman Inc used to have tunnel extentions for Phazers and they were pretty reasonable. ($100) I have made several out of sheet metal that worked really good until I tried to lift the back of the sled. I've mangled 2 of them because they were too thin. Try 1/16 or even 1/8" aluminum and overlap the tunnel around 6" or so. I had them bent with the running boards too so i could just put the stock rear bumper back on. I dont have the sled anymore or I'd attach some pics, sorry.
