PZ-SRV secondary clutch?
stinger440
GR MI
My 84 phazer seconday clutch is pretty beat up, I have a good secondary from an SRV, would it be ok to just switch them out? I checked the parts fiche and most of the numbers match up, just a few washers/spacers different. If I can should I transfer the spring from the phazer clutch over to the SRV? Thanks Oh the reason I want to replace the phazer clutch is it looks like someone hit it with a hammer to get it off the shaft. There are chunks missing around the top edge in 3 different places.
If no one can give me a reason NOT to, thats the plan. I just hope the SRV spring is a little stiffer. The phazer clutch is slow to backshift.
