96 Vmax 600 Mountain Settings?
Schmutt
I have a 1996 Vmax 600ST Mountain Max and just wondering if anyone can help me with the mountain settings. This is what I have for the "SmartCarb" settings based on 6500ft:
Jets- 160
Pilot Jet- 65
Pri Spring- WSW
Sec Spring- R
Weights- 8CR
Jet Needle Clip- ???...I Think 1.5
Pilot Screw- 2.5 tunes.
Anyone confirm or help out?
Thanks Very Much!!!
Not sure about SmartCarb settings, but I'm running a 96' XT600 around the same elevation, and it pulls real hard with perfect spark plug colouration.
Mains 146.3
pilot 2 turn out
Jet needle 1.5 shim on bottom
23/37 gearing w/ 8T drivers (1.5 X121 track)
primary GPG (2shims) w/ 8AB 2.4 grams heel, tip empty
secondary green at 70deg. (89L belt)
Those settings are almost dead on with what I have for Non-Smart Carb settings and thinking I will go with those...Thanks for the Help!!!
