SRX700Andrew
I have an adjuster and haven't used it in a few years. I want to reinstall it but I have a few questions. First I believe I need to cut down the aluminum spacer but I don't remember how much. Second, what about the big washer that is normally used with the stock set-up? Should I not use it with the adjuster?
speedracer
- Jun 10, 2003
Cut .350 off the spacer and no washers. Also remove the original adjusting bolts and washers from backside of clutch.
SRX700Andrew
Thanks for your help speedracer!
