Yooper Dooper
I am having trouble getting my SRX track to sit flat on the groud. I have talked with some TY members and have gotten it close but not completely. Limiter strap is pulled all the way up...both shocks are set very soft under the tunnel....taken out top shims and added about an inch of shims on bottom of transfer rods. I can't seem to strap the front shocks down without lifting the rear skid off the floor even more. Now...192 chissel studs with other mods and the sled rocks hard off the line but problem is the skis hang way longer than I care for... any other suggestions would be great. Thanks guys
valin
Pull the limiter straps off, and drill new holes in them so you can then crank them down even more. Do one side at a time. When you are done, your W arm will be pretty close to the rails. You want that track to sit flat on the ground.
777SRX
the best way to get you shocks right is to make two spacers for the front shocks.take the shocks aparts and put these spacers in. recharge the shocks and your are done with the front. now you need to remove the rear shock on the rear suspension and do the same with that one. Pat Hauck can do this for you as well he has the spacers. Like Valin said your W Arm need to be about touching the front rail.
