-95 Vmax 700 Big Bore: Help with traction
Lorre
Sweden
Hello
I need to get more traction. Adjusted the boggie to give more traction but it isnt enough. So I need to change the track.
What kind of lug hight should I choose and how small drive sprockets can I have before they be too small. If there is such a thing.
Thinking of no-slip wheels if im going to change them to smaller size.
If anyone could help me out it would be appriciated
Edit: Thinking of 1.25" Studs, Hacksaw 1" lugs and 7 teeth sprockets. Do I need to change gears and chain with that setup?
1" track will fit with stock drivers- 9 tooth. 1.25 will also fit if no studs, if you plan to stud it go to 8 tooth drivers & then gearing needs to change. No need for 7 tooth drivers.
