ok i've gone around and around with this sled and am looking for some answers. i have a 94 v-max with a 96 proaction skid in it. i put a 1" carve track in it and it was touching my heat exchangers in the front. so i went and got some kimpex 8t driver and put them in along with a set of 1.5" drop brackets. tracks in and its all back together , but i have maybe a 1/4 inch clearance in the very front. so if i ever want to pick it im sure ill be doing another driver swap to 7t's.
im curious as to what size tracks people have in thier 94-96 v-maxs and what you had to do to get them to fit. is there such a thing as a picked 1.25 track in one of these sleds ?
I put a 1.25" ripsaw in my 96,the top of the lug's were bareley touching the heat exchangers up front.People I've talked to (including mechanic's at yammi) said it was nothing to worry about the lugs will just wear down a bit JUST DON'T STUD!
Looked a the heat exchanger's after about 100 miles and they seemed fine,just a little black residue on them
n8sjh
94 vmax m-10 running 8 tooth drivers and 136x1.5x15 track. lugs rub about 1/4inch on the top heat exchanger guards. No studs
