2004 Viper S clutching help
beardsley
Ottawa
I bought my 2004 Viper S back in December and I am trying to set it up. It came with:
Simon's CPR tripple pipes
Simon's CPR heads
Heel clicker 2-speed clutch (red spring)
Jetting changed (person / couldn't figure out what size of jets)
I blew a belt back a while ago and the twine inside the belt tore the heel's off 2 of the 2-speed clutches so i had to go out and buy a new clutch kit. I Purchased a Heel Clicker STS3HC-10BY.
This is all of the info i have on my sled and I am fairly new into snowmobiles so I cannot get any more information from just looking.
I am looking for someone who can help me out with a starting point for what weight i should run in my clutch.
(My plan is to purchase a 48/34 helix and red secondary spring but for now i would like a setup to run now)
Aggressive Trail riding.
*sorry if this is a beaten topic i searched the forum for topics like mine but i was unable to find it if its there.
UPDATE**
So i went out for a rip today on the river.
i believe i am running a stock secondary.
4.5 in the heel nothing in the center and 3.3 in the tip - red spring(as specified by HC)
I had it up to 111mph on the speedo.
Im running cprs but with a heavy hitter clutch kit. Dont know much about it yet but that is my summer project. It was set up by jeff simmons. I do know that i shift at 9100rpm and it seemms perfect all the way through the band. You got a few more balls then i do as ive only got mine up to 94 on rough ice and backed off. It does run nice though. I also am running a stock secondary. Im also running jeffs jetting. Do a search and that will come up.
thanks. i will look into that!
im going to be buying a secondary spring and helix to help with my tunning and then find the most reliable power setup i can.
if you have any other tips keep me informed!
clutching
ok so i tried the whole marker on the primary sheave and it wears it off until about an inch and a half from the top.
how close to the top should the belt be getting?
ALSO
i was told that i should take my sled run a few pulls with it and see how hot they are. if one was hotter than the other it means thats where its slipping and i should be able to touch both of them.
well i gave it a shot and both of them were extremely hot.
what should i be changing?
HC 40-10
4.3 heel 3.3 tip
red spring
stock secondary
Simons CPR pipes and Head
