will these tools work
Howden ,Manitoba,Canada
will the clutch puller and clutch alignment tool that I have for my sx600r and srx work on the 95 clutches.Or does one need a different clutch puller.Got to find out also what type of rollers and weights are in the clutch of the v-max 600.
UPDATED RESPONSE:
Clutch puller should be fine on the 95s + up.
The offset[15mm] and centre to centre[268.5mm] are the same between the Pogo stick 95 twins and the trailing arm SXs + SRXs so the allignment tool should be good to go as well.
Yesnthe clutch puller will work, The tech section has a nice extra info section in it with all the clutching and jetting specs. My 95 600 has 8CA-01 weights in it, not sure about rollers though.
Yeah I saw he got the same sled as me, I know it rides a little harsh but it is paid for and goes pretty good. It's fun to work on too and clean up and tune, plus they look really cool IMO. There is quite a few guys on here with Vmax's so there's lots of help from guy's who have experience with them, I have learned a lot in the month or so I've been here.
