Help!!! Temp Light
stuffer
Saskatchewan, Canada.
Hi all... can anyone help with the flashing light? Took my carbs off to clean reinstalled with bigger mains due to the ported cylinders. Lifted the *** end of 02 SRX at least 4 feet off the ground to bleed air out of system. Temp light still flashing. Two regular flashes then a short one! This is all after the initial flash sequence.
Thanks,
ChrisP
Thats hrottle position sensor disconnected or short. Did you get it plugged back in good Maxdlx
