fine tuning my clutch
Concept Carbon
Ottawa, ON.
So Here is my setup hcs
I have
9grams tip
center empty
6.3grams heel
50/42 dalton at 60deg
23/38gearing
So when I go from a stop it revs up emidiatly to 8500 climbs so 8550 then drops smoothly to 8100 and climbs. Im seeing 120mph-123mph on speedo.
I would like it to rev 8300 out of the whole and climb.
Would I be better off going to a 52/40 helix which should get me close or removing some tip weight and adding center weight?
Take some out of the heel & tip add to centre. Your heavy loaded heel is pulling from the tip on top & mid & vice versa. I would take out 2 grams from heel, 3 from tip & add 4 grams to inner for starters.
If you balance everything just right you will have a full steady shift right to top end ....but it,s gonna take some trial & error.
this is what i try to tell u lolll
I will be going to low on sunday and ice fishing satarday morning and looking to do some rideing on satarday night, unfortunatly I broke the bolt that holds my rear shock in my edge skid. I have my fingers crossed that I get it by the weekend. Its a stupid polaris bushing/nut sholder bolt.
Concept Carbon said:
lol I was there when he showed up with a flat tire, we could hear him coming for miles away lol.
yeah so crazy sometime lolllllllllllll :letitsnow
