cheapsx
Just wondering what kind of RPM's you guy's see with your sleds on the trail. My set up with psi pipes I am getting around 5500 in woods doing about 20 mph. Maybe 6500 - 6750 at around 40 going down the lake. Around 7250 - 7500 at the 60 -65 mph. I feel i have the best set up yet but I am afraid it,s turning to high in the trail. The motor seems happier at that 5750 rpm point. Is that where the pipe starts working well? I have got it so it shifts nice and even, goes to 9100 and sits there all the way to top speed. Leave it alone or drop engagement a little?
VenomMod
My 600 with AAEN's at WOT runs at 8950. I've found the pipes like it there. Anything over 9050 RPMs and it peters off.
Not sure what your getting at cheapsx, Different pipes make different rpm at different speeds. Depends on clutching, jetting, mods, track..etc.......
700triple
You will want to be at 9000-9100.
Bluenote
I have usually am sitting in the 7500-8500 range on a normal trail, powder session, on the ice though, 9000 easy. You will know when it starts to crap out. Or get a gps or borrow a buddies and you will know for sure your powerband and where it craps out. It you are after top end though, re-gear it. But I doubt you will like it since tripples are not TQ monsters so you will lose bottom end worse the a twin would. But your top end would be insane.
cheapsx
TY for the replies I guess I asked the question incorrectly. I know my pipes make power @ 8800-9100 current setup puts it right there. I know some of you guys are getting better fuel economy on pipes than others of us. I was more interested in say trail riding/cruising RPM's everyone is turning. I am thinking mine are a little high and am trying to be able to go at least a 100 miles on a tank of gas. My therory is, but it could be BS, a little higher RPM may let the pipe work better giving better economy. If thats not the case do I want it turning lower? I know all set ups are different but was wondering what works best for others.
yamahauler4
Mine with stock pipe from a dead start will run to 8700ish. From a roll, tops at 8500. Just happened to notice this week on a r/r grade that it runs 75mph GPS at 7500 rpm. Tops out GPS about 95-97mph. Running 1.25" track, and 41t lower. Thinking I'll try a 21t upper for even more low end. Don't care about going much over 90mph anymore.
mine run right around 9000
boondoctor
cheapsx said:Just wondering what kind of RPM's you guy's see with your sleds on the trail. My set up with psi pipes I am getting around 5500 in woods doing about 20 mph. Maybe 6500 - 6750 at around 40 going down the lake. Around 7250 - 7500 at the 60 -65 mph. I feel i have the best set up yet but I am afraid it,s turning to high in the trail. The motor seems happier at that 5750 rpm point. Is that where the pipe starts working well? I have got it so it shifts nice and even, goes to 9100 and sits there all the way to top speed. Leave it alone or drop engagement a little?[/ What type of helix are you using? A multi angle 51/43 for example works great on my Bender piped 700. Snappy down low, and good top end and easy trail cruising. Acts like a 2 speed transmission.My 2 cents.
