Spinner18
Newb to srx's. Read lots about carb cleaning. What style carbs are on these sleds? every polaris I have worked on has rack style carbs, and I've never personally cleaned one and never had a reason too. What goes into carb cleaning exactly? I am sure others may be wondering the same thing.
carbs are 33mm flat side ...mounted on a rack ....pull rack all together ...remove the bowels from bottom pull main and poilet jet clean the and blow thru passages and make sure float doesnt stick ...reassemble and you are done
madzx2
its actually very easy. its a lot better than pulling three seperate carbs i think anyway.
onewickedr1
Something w/maybe the compound of material used. For some reason the literally from time to time will booger on you. You really need to run premium fuel and keep em clean.
