Clutching help needed
01sxr700
Thunder Bay, On.Ca.
Last year I put a 144"x1.5" crossover track in my sxr700 and had clutching problems. So this year I changed the clutching to MM specs. Have stock MM helix 43 deg, weights 8cr, rivets 10.3al/10.3al, 14.5mm rollers and springs (ywy primary, green secondary). The only thing slightly different is the gearing. The MM setup is 21/40 and I have 21/39. My problem is over reving,when I punch it, it goes to 9400rpm then back to 9200 and holds there. Do I just need to replace tip weights with heavier and if so which ones. Engagement is at approx 4700 which is stock for the MM. Any help would be appreciated.
