2000 srx temp light come on under hard pull also the fuel & tach don't work where to look
One prob at a time here,,
get us a light sequence so we can look up the code. Did both problems start at the same time or????
yes both started at the same time
Can you tell if there's any sort of light sequence?
i think that the fuel is because of the little relay by the sec cluth but have no clue why the heat light comes on under power
Are carbs clean along with the power valves? Check that servo is working... Could also be rub through,, with wiring harness...
carbs clean servo working great know there is now rpm gauge is bouncing all over.
Do a search on wire rub thorough,could be the problem here
