i changed tracks on my sled with a 94 v-max xt rear skid in it. everything went back together alright but i have one small problem. the boggie wheels mounted towards the front of the rail on the inside of the rails wont fit correctly , one side sits right on the lugs. tried swapping the mount and same problem. and i know on the newer proactions they are all mounted on the outside. i circled the wheels that are giving me the proble
would there be any problem running them on the outside instead of the inside of the rails ? track is centered and adjusted , other side rides fine and is centered in the lugs. i did change to the newer style wheels but the other side works fine. just that one wheel mounted on the inside. any suggestions ?
