cajones2
Over the summer I had some mice setup shop under the engine. I was able to successfully evict them shortly after realizing this. This fall i pulled the engine to get the varmints out of there, clean out their condominium and check all my wiring and hoses for chewing and what not. I got everything back together, but looking back i should have bled the air out of the oil line between the reservoir and the pump since it is mostly air now. I tried to hold the throttle open and shoot a little air in there but that did nothing. I am wondering if i can use a couple gallons of premix and let the engine pull the oil in. I really don't want to have to pull the engine and drain, but would if i have to.
Do you think running a couple gallons of premix would purge the air out of the oil line ok? Would the additional air be a problem causing the fuel/air mixture to run lean?
Thanks guys! -Craig
Thanks guys! -Craig
