SRX belts, adjustment, plugs
Spinner18
Virginia, MN
had a chance to get out my newly acquired 01 srx today. First off, what belt do these run, i cant read the belt. Also, what kind of tension should be on these, the top of the belt sits flush with the secondary clutch. is this too loose? what plugs are ran? sled as aaen triple pipes.
how do you adjust belt tension on the secondary?
I could pull about 109 on the speedo on a straight stretch on the trail, about 3/10 of a mile according to the trip. is that decent? previous owner was 1slo_mm, and used turks advice as a baseline set-up, going to get the clutching info from him and will post when i find out. It seems to over rev some, hammer down and it's at 8600 then climbs to 8700. raced my buddy on an 08 xp 600 thats clutched, from about 40 mph, he jumps a half sled until 75 then i sail past him. he could pull about 105 on his speedo. light dusting of fresh snow and a little chewed up trail. got out onto a lake and pulled about the same speed on the speedo, got about 111 speedo.
is it a 700?
use the yamaha 8dn belt. i think the spec for belt hight is 1.5mm above the secondary. thats what i keep mine set at. i believe the plugs should br9ecs, thats what is called for on the 2000 srx 700. to set belt deflection there is three bolts on the backside of the clutch with shims. im not positive on exactly how to do it that way because i use a external deflection adjuster.
my 00 srx 700 goes 97mph in 2/10ths of a mile and thats on gps, speedo says 100mph. doesnt sound to bad to me.
