I have tested the stator and i got power and i also tested the ingtion and getting power too i also tested the plug before the coils and i have no power anywhere ideas where else too check or has anyone else had this problem....
Kill switch?
Waters88
My guess would be possibly a problem with the kill switch, the time I had that it was my pickup, but seeing where you have power I dont think that could be your issue.
is there any way to bypass the kill switch?
I believe to bypass the kill switch you unplug it.
I unplugged the kill switch and that didn't make a difference and i check the orange wire into the cdi no power but i don't know what wires should have power going to the cdi anyone know?
white/green and the red/white in the black connector in cdi both come from stator ...and chocolate color wire seem to be the ground in the white connector
