I have an 89 yamaha exciter 570 and i decided to add some 2 stroke oil. well I accidently put it in the coolant overflow tank, about half a quart. I ran the sled for about 15 miles afterwards. no problems. Should I drain the coolant and add new or will it be ok?? What for coolant should I use?
did it stay in the over flow or did it make it's way to the main system???
its still in the overflow cause when i looked at the overflow tank it was blue, the color of the 2 stroke oil i used. although it is a lil lower then when i filled it so some may have gotten in
I would flush find the drain bold or a service manual and have at it,add back 50/50 mix good to go.
