hey guys im have so problems with my suspension with it bottoming out. it is a stock suspension extended with a ripsaw 136 track on it. everytime i do a small jump it bottom out. which way do i turn the spring and did anyone found a alrite spot to put the suspension to get a little bit of both worlds.(trail and jumps) if u did can u measuer the gap.
Set the FRA in the second setting then.The point where the front of the rear shocks attaches is your settings.
