01 sxr weird sound?
j_k son
PA
i been out riding around close to my house and i started to hear a ratcheting sound for under neath the hood. the sled rides good.i have a 136 track and i also have the benders clutch and stock secondary.my belt is tight and dont have shims to fix it we have small washers on it now.the ratcheting sound started after my dad and i put the washers on. the sled goes with no problem when i want it to so any ideas????????
bolts
The 2 Carrige Style bolts on the Jackshaft should have the nuts toward the chaincase. If they are the other way it will hit the 3 bolts that you adjust belt depth when you add washers
