Said dragon #1 to dragon #2.
This post is about YPVS assembling.
I bought the whole works, from the wire to the last seal. However, I can't figure how it goes together. There's this circrip that is supposed to be in there but theres nothing to attach it to???
http://fiche.worldofpowersports.com/wps/Yamaha_OEM/YamahaSnow.asp?Type=13&A=276&B=1
#26.
Help?
#26.
Help?
there is a groove at the end the the cable housing,once it goes through the pv outer housing and thru the cable guide,you snap the c-clip to hold cable from coming back out.
Uhm okay? what about #25? Since the groove is taken by #26, #25 just sits loose???
sgauthier
#25 goes underneath the c-clip, the c-clip holds it in place and keeps the cable from coming out.
clear as mud??
this is why you should only take one of these apart at a time so that you can refer back to the other one that is still together.
clear as mud??
9801srx
#25 is just a flat washer it goes between the c clip and the power valve housing , you have to push the cable housing into the power valve housing enuf to compress o-ring 27 then you will be able to get #25 on and # 26 holds everything in place .
Ya I figured it out at last. My first YPVS assembly complete, now just waiting for the "practice cylinder" thanks guys!
sgauthier said:#25 goes underneath the c-clip, the c-clip holds it in place and keeps the cable from coming out.
clear as mud??
That's exactly what I did
