Igniton timming Graph
Bullit01
Bonfield
Hey guys I was just wondering if anyone had a ignition timming Graph on the 2001 srx?
I did a search on here but didn't see it. Do you just have the valve timing spec or is it a graph?
2000+ SRX timing:
7750 - 18 degrees
8000 - 13.5 degrees
8250 - 10 degrees
8500 - 9 degrees
8750 - 8 degrees
9000 - 4 degrees
9250 - 0 degrees
valin gave this to me...
Viper Ignition Timing
24 degrees 7750 rpm
18 degrees 8000 rpm
18 degrees 8250 rpm
18 degrees 8500 rpm
15 degrees 8750 rpm
13 degrees 9000 rpm
11 degrees 9250 rpm
I am doing an overhaul on my viper, how would I adjust the timing? the stator is pre-made to bolt on directly, and the flywheel has a woodruff key. Sorry for hijacking the thread.
The simplest way to adjust the timing is by installing an offset timing woodruff key to advance or retard the flywheel position relative to the crank shaft. Hauck used to sell various timing keys.
Thank you Valin. Hard to believe I had to advance timing on my motor to make power with that much in the cdi.
