SRX brake light sticks on
Roscoe
SE Michigan
The brake light on my 01 SRX sticks on. I've found that when I wiggle the brake lever it flashes back and forth. When I push down on the brake lever (towards the running board) just a hair, the light stays off, let up it comes back on. Is there adjustment somewhere?
no adjustment but you can remove switch and pull it apart. clean out corrosion and if its still intact put dielectric grease in switch and put it back together. that worked for me.
