Bearit
Hi there,I have a 2002 viper with aaen pipes.vforce 2 reeds,cpr heavy hitter primary setup with there spring,I need to know what color secondary spring I should run with the stock 47 helix.looking for more top end than bottom.
Thanks Steve
Thanks Steve
jwiedmayer
I ran the yamaha green with a 42/35 maxx roller and the HH spring in a piped and ported sx.
try a white or pink, green work good too...the other two have more side force
Bearit
Mr Sled could you please explain what the stiffer springs will do,are we trying to ballance the secondary to the primary because of the heavy hitter primary spring?
Thanks Steve
Thanks Steve
back shift faster, hold the belt tighter, hold the shift back longer...hurt the top end slightly...
