NY_SXR700
Buddie has an all stock 97' XTC 600. He noticed it was running "poor" as he puts it. He thought a plug was fouled out. I looked at his plug and it had alum on it. We pulled the head and I saw something I have not seen before. All my piston fail from heat (too lean). His is just fat and black. His piston looks like a bottle open pulled it up on the exhaust side. It's not melted as all the metal is very sharp and jagged. Is this something that happens on this motor? I want to know, as I have not seen this before. He drove it 65 miles back to the truck on one cyl, as he had no idea he lost one. He also said that is happened wen going slow. It just popped and started running crappy. Ohh, he was also running a B9-ES plug and not the BR9-ES. Would not using the resistor plug be a problem?
I bet when you get it apart the ring locating pin is gone. I am guessing it is a twin, and they did have that issue on some. When the pin falls out the ring spins, and the ring end catches the port. Maxdlx
NY_SXR700
Yeah, something along them lines I was guessing. It's not melted for sure. It's ripped open and the cyl is hammered more than any I have ever seen.
ottawaair
'97 had ring problems, probably around 3,500 miles on the sled???
NY_SXR700
Well, I think it has around 3500 - 4000 on it. I guess I will re-ring the good side for him as well. Was it a piston change or just bad rings? tks
It's a known issue for the 97 twins. Mine went at 2500 and warranty covered 2 jugs, pistons, rings , gaskets and labor. Use the newer, 98, pistons and rings. I have around 6,000 miles on mine since the rebuild and it's as strong as when it was rebuilt
ottawaair
Replace both pistons, good or bad. The problem was the locating pin would break & let the ring rotate atound & catch the port & break. '98 & up pistons are good, or aftermarket, but i like oem.
