99 SRX clutch settings
rogerz
CT
Hey guys,
I have a 1999 SRX 700 and have done the primary clutch mod on TY. I am now going to set the spring on the secondarry clutch. The Specs that are on the tech area for this sled say 6-1 (70). Does that mean hole 1 in the inside, and hole 6 on the outer helix? If so, are the inner holes marked? I can't find any numbers..
I see the number 70 on the outer part, but I see 8BV on it as well. It should be stock i believe. Is this cool to go with?
Thanks for the help!
Roger
