REDMATER New member tya Joined Dec 20, 2003 Messages 1,210 Age 60 Location ny Website mysite.verizon.net Dec 4, 2004 #1 is there anything to watch out for other then torquing specs should you grease the crankshaft spline just curious dont want to damage anything
T TJ500 Member Joined May 17, 2003 Messages 661 Location Lockport, Manitoba. Canada Dec 4, 2004 #2 don't put lube on cranckshaft or clutch mating surfaces... clean surfaces with alcohol.... do put a little lube on threads of primary clutch bolt however..... TJ Last edited: Dec 4, 2004
MrSled Site Admin/CEO Staff member Joined Apr 25, 2003 Messages 9,936 Age 55 Location Weston WI Website www.totallyamaha.com Dec 4, 2004 #3 I clean up the pto shaft with some emery cloth or scotch brite
REDMATER New member tya Joined Dec 20, 2003 Messages 1,210 Age 60 Location ny Website mysite.verizon.net Dec 4, 2004 #4 cool thanks
FuzzButt New member Joined Dec 5, 2003 Messages 694 Location Waterford, Michigan Dec 4, 2004 #5 Redmater, You sure ask some good often overlooked questions.
REDMATER New member tya Joined Dec 20, 2003 Messages 1,210 Age 60 Location ny Website mysite.verizon.net Dec 5, 2004 #6 well a dumb question is the one that is never asked......
