teamblue02SRx
my track was to tight so i loosened it started it tun the tracks acoupleof times to se if it was out of line it was got the track lined up and now one side of the track is tigher that the other i know that this has been talked about before but i just cant figure this out i folowed my ownersmanual instructions , if the trackis line up the tension is diff on either side if the tension is the same the track is not lined up, some help would be greatly appreciated
Check your w-arm. The bushings in the suspension could also be gone. Both of these would cause your skid to be crooked.
