Canuck
This problem is with a 99 600 Vmax Triple
Last season the bearing went in the R/R rear idler wheel and the track tensioner bolt hit and bent a track clip. We replaced the idlers, tension bolt and straightened the track clip. Then at the end of the season the outside edge of a track clip bent up and chewed up the hyfax and slide rail. It was the clip that had been bent and we figured it was due to the previous damage to the clip. We replaced the hyfax, right rail and removed the damaged clip.
Then this year the outside edge of a left track clip bent up and chewed up the hyfax and rail. We replaced the hyfax, slide rail, and removed the damaged clip. This was on the opposite side of the sled to the original damage. The track was given a very thorough check and no damaged clips were found.
On the second ride this year another clip bent up on the left side and chewed up the hyfax and rail. I've never had a problem like this before and I don't know what is causing it.
The sled has a 1" Camoplast Predator, fully clipped, with about 1k on it. When I bring it in the garage I will take a photograph of the clip, it's just the very outside edge where the hyfax rides is bending up at about 90 degrees. Has anyone ever had anything like this happen? Now I'm fresh out of rails and I'm thinking of replacing the track also.
