Mountain SXr
Hello,
I'm just about to go for my first ride of the year. I just installed tripple AAEN's and was wondering about clutching. I don't plan to clutch according to instructions, because I'll be poweder riding and don't want to engage at a high rpm. Can I leave it stock or should I change it?
How about the "redline" Where is it on a 700 yami? What should my peak rpm be?
Thanks,
-Jon
Thanks,
-Jon
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
I know that the stock peak in the SXr is 8300 but I am positive those pipes will change it. Anyone else?
Turk
TY TECH ADVISER
- May 2, 2003
The aaen pipes should run at 8900 rpm on your sled.
yamaholic22
Yea they are real happy around 8900-9000. I had two sets of those, they are pretty decent pipes
yamyrider
do you have any other mods on the machine. Did you re-jet for those pipes.
if there are other mods you may be over-reving.
Mountain SXr
Pipes
I rejeted one size bigger. Otherwise motor is stock. Mind you, it's an SXr 700 with a 141 extension with 2" lugs. I didn't change the gearing, hasn't been a problem yet.
I engage around 4000 rpm, which suits me fine.
I was mostly curious as to how high the motor could rev without there being a problem.
-Jon
-Jon
yamaholic22
that engine will rev all day at 9000 without a problem, very well built. Go try revving like that all day with a cat, just make sure you bring a net to catch your pistons before they land
BlueIronRanger
- Nov 26, 2003
My wifes V-max 600 tripple has 2500 miles on it and it revs 9100 rpm @ WOT (which I'm soon fixing) the previous owner didn't know much about sleds and just rode it hard like that.
Mountain, I also have a 2" paddle and pipe and never once changed clutching and have riding it for 3 years now that way. I rev around 9000 when crossing water, but usually dont tach out in most snow conditions! Just my opinion. Brent
