lakeofthewoodsrider
Isw there any way too get rid of the inside ski lift on the srx when turning at a good speed. when on the lakes, it lifts too the point that it feels like it wants to roll.
Move your rear end over (to the inside) and apply pressure on the outside foot to balance the sled keeping the maximum pressure on the outside ski without lifting the inside ski too much.
As far a sled setup, we don't have any idea what setup you have now.
its all about butt shifting.River is rough here and at 80 around the bends my ski's are lifting to,really have to shift my butt over.I have ohlins and they are set preload to specs and about 7-8 clicks out.Don't know what you have for front shocks..but wanna figure out how to tune the Ohlin's as they are new to me
I've heard of some guys using a venture sway bar. I guess its a bit thicker thus producing less body roll. You can also tighten up the front spring preload. Just remember the stiffer you make the susp. the rougher the ride.
I ride with no preload in the front. I also like about a 1 foot inside ski lift while in the corners. For me this is the fastest way to go thru the twisties or even on the river.And like Ding said with outside foot pressure helps alot as well as leaning alot.
