Bluewinter
First off let me thank those of you for your input. For those who haven't read an earlier post of mine my issue was 2 of my plugs were tan colored the othe was if I had just put it in new. Checked my spark it was ok. Checked compression, ok too. No fuel smell on the plug. This is what I found. After taking my bowl off my carb and seeing it was bone dry I realized I wasn't getting fuel to the carb at all. I was pretty confident that if the pump was bad I wouldn't get fuel to any of the carbs. And if I were to get fuel the no. 1, I was thinking would get it before any of the others. ( least distance for fuel to flow) Well, the float seemed to be working fine. However, I took it apart anyway. There I found that the needle wasn't able to move freely. Please someone correct me if I am wrong here. I am sure this is supposed to be able to slide up and down with the float. Then with the float almost all the way up it then pushes up on the little spring loaded pin and then shuts the fuel off completely. Is this correct?
