SmonsterX
- Dec 4, 2004
ne1 ever used these or know if there any good?
they say u don't need 2 change your clutching or jetting, any comments on that??? heres the web site http://www.mountainperformance.com/original.htm
n2oiroc
over 100db. that is extremely loud! i would find something else.
DoktorC
I think there where two versions of the GYT pipes. The first which were introduced in 1998 were Power Inc pipes...of which I have a set. Very strong pipe but they are loud. Later years I don't remember. You can do a search (on this site) on Power Inc and you'll get a ton of info. Clutching and jetting must be changed with these pipes..an extra 20+hp really makes a difference.
Turk
TY TECH ADVISER
- May 2, 2003
The 1st generation GYT triple pipes were Power inc. end dumps. The next year they were Dynoport(Benders). Yammie got out of the pipe biz the following year.
DoktorC
On further investigation it actually says Power Inc on the MPI site....so there you go.
here i asked the same question,heres is the link
http://www.totallyamaha.com/forums/showthread.php?t=6631
SmonsterX
- Dec 4, 2004
thanks a ton guys!! probally gonna put the money towards a new track and some studs instead! goin up nort to do some riding in a couple of weeks !!!!
yamahauler78
You can get the can mod at Fix Power Sports for $89.95, this will give it a racie sound (not extreme) will fall under the decible allowance and if you adjust cluthing you will get 7-9 HP increase. www.fixpowersports.com
